Difference between wireless chargers
(Topic created on: 26-11-2019 10:30 PM)
Firehawk
Accessories
The Ultra Thin wireless charger has basically the same output eletrical specs as the Convertible Wireless Charger and the Wireless Charger Stand.
So why then would anyone want to buy anything other than the Ultra Thin, when all the others have fans in them that make noise and are more expensive?
Can the non ultra thin ones charge phones through thicker cases?
With the nicer looking Convertible, here in the UK, you don't even get a mains adapter nor a cable.
What does AFC stand for in AFC Wireless Charging Pad (inc. mains adaptor)?
0 REPLIES 0
