Go to solution Solved
How do I return a Samsung Gear s2 Classic purchased from the Samsung Uk online shop.
(Topic created on: 30-05-2017 07:10 PM)
BandOfBrothers
Samsung Members Star ★★
Hi,
I'm wanting to return a watch within the 28 days cooling off period.
When the watch was delivered it came with a Return Label.
When checking the returns process it talks of...
Log into samsung.com.
Then MySamsung.
Then it says to go into 'Shopping Support' then 'Orders' but I can't find these two anywhere on the site page.
Help ?
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
ThomO
Pathfinder
Hi, @BandOfBrothers
It would be best to contact the Online Shop Team Directly regarding this.
You can find their contact details here and their support number is: 03307267467.
Hope this helps!
2 REPLIES 2
ThomO
Pathfinder
Hi, @BandOfBrothers
Hope this helps!
BandOfBrothers
Thanks.
They are sending a Courier to collect it.
