06-07-2017 01:05 PM - last edited 17-05-2019 10:34 AM by AntS ) in
My watch charged fine for first week then stopped charging when on charger. A factory reset seems to have cured. Anyone else had this issue and anyone know what caused this issue?
Thanks
06-07-2017 02:26 PM
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
02-08-2017 12:46 PM - last edited 02-08-2017 12:48 PM
Make sure all the points of contact,don't have a build up of skin gunk even after a relatively short period
if you don't wipe your gear over regularly,sweat even tiny amounts build up and can be bad for your gear,
my own gear fit 2 has the four corner holes that can build up gunk and two gold contacts just off centre make sure you give it a wipe over as sweat is corrosive and will make them rust.
