@Gear14: If you have valid proof of purchase and the Gear Fit 2 is inside the 24 month warranty then you can take the band to a Support Centre where an engineer can remove the FRP lock for you. To find your nearest one please check the following link, select 'Mobile Device > Phones, Tablets and Wearables' and enter your post code.
