22-05-2017 09:53 AM - last edited 17-05-2019 10:15 AM by AntS ) in
Hi everyone
I got a free gear fit 2 with my s7 edge in febuary and I think it is an amazing peice of kit
in the box you get the watch and the smart little charging stand that as the ability to fit quite a few chargers.As I have read not using the correct chargers for the device is at best not good and may damage the battery and overall lifespan of the battery (device)
Which is the correct charger to use.
I have my charger for s7 edge but that is a fast charger
I also have a triangular shaped one that I have been using that seems to be an apple charger.
I have done loads of searching but no one has a definitive answer.
can any one here give or get the correct info please. as it seems some of you guys have loads of knowledge but also access to answers to questions some of us struggle to find
Thanks
Solved! Go to Solution.
22-05-2017 03:48 PM
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
22-05-2017 03:48 PM
05-05-2020 01:16 PM
