Hi
@Lynne-74In order to connect the Gear Fit 2 to your Galaxy S10e you will need to download and install the Galaxy Wearables app, available from the Google Play Store and the Galaxy Store. Once installed, please open the app, tap on Start Your Journey and follow the on screen prompts. If you had the Gear Fit connected to your previous phone then please make sure that you disconnect/forget the Bluetooth connection it before attempting to connect to the S10e.
