smart Remote battery Cover!
(Topic created on: 31-01-2018 08:12 PM)
Neill1221
Has anyone had trouble opening the Battery Cover on the Smart remote for the MU6400 Series TV??
It's murder trying to get it open!! Very badly designed!!
32 REPLIES 32
AntS
Intriguing solution, @Nurse1! How did you come by that?
Nurse1
I am serious. The heat from the blow dryer loosens any gunk that might be causing it to stick and makes the plastic more pliable. Came right off. No problems. Just around the edges. I also use this method to loosen plugs from gastric tubes.
Neill1221
Well,you shouldn't have to do that with any remote! It's not even a year old yet!! Badly designed!!
anon26
Hello, did you have any trouble putting the cover back on? My remote also had trouble getting the battery cover off. But after days of trying it finally snapped. But now I can’t close it. It’s been open for months now.
SpenceFamily
Yay! The blow dryer did it! Couldn't get that dang back cover to move for nothing! Read this helpful hint about the blow dryer and BINGO! We have a Winner! Thank you @nurse1! Hubby and I are grateful, even if he's still grumpy about me getting it off first! 😉
brisween21
Same issue here.  I've seen the same issues on You-Tube.  Anyone have a solution?  I've tried to push down on the arrow as hard as possible and light at different angles.  It will not budge.
@Neill1221 wrote:
No not yet! I wanted to ask if anyone on the forum had the same issue! As I said before I saw some complaints on youtube
with this problem,so,I decided to ask here  to see if there was the same issue!! I still think It's a bad design!! It's the MU6400 series TV  Smart remote!!
LowriderSoCal
I used the dryer method and..................IT WORKED AS ADVERTISED!!!! Thanks! I was getting frustrated and what happens with that is "Get a bigger hammer. No need after following the simple directions.
bkaren2
I have this problem from day 1.  It took me 3 weeks to get the battery cover off.  I kept pressing the arrowo and it would not move.  I took my fingernail and coasted the side of the control until it pop out.  My othor problem is that the batteries drain so fast.  I bought the TV in 12/2019 and I had to change the batters 7 times.  The red light keeps blinking.  Something is draining the battery quickly, like every 3 weeks.  It's crazy.  I'm hoping this will b covered under warranty.
Cali-Bob
Used blow dryer suggestion for Samsung Soundbar remote.  It works!
KV5094
Thank you @nurse1!  The design is ridiculous, but your solution works.  Also, once you slide it down about 1/4 inch or less (in the direction of the arrow), it LIFTS off.  Continuing to try to make it slide does not work.
