Go to solution Solved
samsung tv 5 series
(Topic created on: 28-12-2016 12:57 PM)
bernie
why can't i buy a camera for my tv,that actually works!!
EmmaS
Pathfinder
We're afraid this model of TV doesn't support Motion Control.
EmmaS
6 REPLIES 6
EmmaS
Pathfinder
Hi Bernie,
Thanks for posting.
Are you able to give the Community more information? What's the model code of your TV? Have you tried any Cameras so far?
EmmaS
bernie
hi emma,the model number of my tv is UE32H6400,and yes i have tried a camera.
EmmaS
Pathfinder
Thanks!
What would you want to use the Camera for?
EmmaS
bernie
motion control,i think its called
EmmaS
Pathfinder
EmmaS
Tv5series
Hello Emma, I have a 5series smart tv and the audio will not work, i have reset several times and it is still the same thing.
