UE55NU7100 Freeview
(Topic created on: 02-01-2019 06:25 PM)
Deniz2
How do i acess the channels on freeview?
it tells to me connect a anntena?
7 REPLIES 7
paul1277
Black Belt
It's normally known as an aerial.
Deniz2
I didnt come on here to ask what its called...
Either answer the question or kindly f off.
paul1277
Black Belt
Sorry,  but have you got an aerial installed,  which you need to watch the built in Freeview?
Deniz2
No i dont, i was under the impression it would work without it :smiling-face:
paul1277
Black Belt
No you need an aerial for Freeview,  but it is worth it for free tv with all the main channels in HD.  To have one fitted is normally about £50.
paul1277
Black Belt
@Deniz2 wrote:
Will this work?
https://www.argos.co.uk/product/3336056?cmpid=GS001&_$ja=tsid:59158%7Cacid:532-198-3455%7Ccid:598735...
It all depends on the signal strength and how close to the transmitter you are. There are phone Freeview apps that can tell you where you nearest transmitter is to your location. You could try but an external fitted aerial always gives the best results.
Paul
