09-04-2017 09:42 AM
My wife is dealing with the onset of dementia. She is no longer able to go thorugh the steps to change the input on the TV. Can I force it to default to TV every time the power button turns it on?
Solved! Go to Solution.
11-04-2017 12:26 PM
Hi @CharlieM.
You may need to reset the TV. Go to Menu > Support > Self Diagnosis > Reset. When tuning in the channels again, make sure you select the 'Aerial (Direct to TV)' option. The TV will then remember this setting when turning off and on. Hope this helps.
11-04-2017 12:26 PM
Hi @CharlieM.
