05-06-2020 08:29 PM - last edited 05-06-2020 08:30 PM
Hi there
I've recently purchased a Samsung TU7000 UHD TV which is generally great. The only issue I have is when viewing the very few new HDR offerings through Sky Q.
I get an intermittent black screen flash up for a second or 2 at random intervals although the audio carries on. The TV picks up that's it's an HDR HLG signal as this shows on the TV display. The problem doesn't happen on normal UHD viewings. I've tried a different 18gb speed HDMI cable but the issue still exists.
Can any of you Sammy experts shed any light on a possible fix please?
Thanks
05-06-2020 08:46 PM
Hi @Camelface ,
Have you rebooted your SKYQ box by removing the power cable for 30 sec then reconnecting? If that didn't correct the fault, would you be able to try a different HDMI port on your tv?
05-06-2020 09:20 PM
Hi and thanks for the quick response.
Yes, I have power cycled both the Sky Q box and TV. Tried changing HDMI ports and the cable but the problem still exists. Also, both the TV and Sky Q are running the latest firmware so they both appear up to date. Do you have any further ideas how to fix this?
06-06-2020 10:31 AM
Hi good morning to all.i have just bought a new Samsung ue75tu7000 everything works fine uhd is fantastic. I go to the new sky tv channel that is hdr and am getting the screen going black for 2 or 3 seconds.i rang sky and after one hour on the phone I was told this is Samsung's problem. I have updated the tv and the skybox and changed the hdmi still the same problem. my tv is a new line 2020 model and you would think that it would be spot on for all this new stuff coming out.if anyone has fixed this problem please can you let us know thanks to all ad keep safe and well
06-06-2020 10:42 AM
Hi Eddie
Glad I'm not alone lol. I've tried all sorts to no avail on my TU7000. Hoping the Samsung Mod will come back to us on here with a solution asap or my TV is going back under the 14 day cooling off and getting a different brand.
06-06-2020 10:58 AM
Am just over my 14 days but I think it's 28 day's now. I will have to look it up.but I do think Samsung will give us some updates soon. I know thare isn't a lot of hdr at this moment but that's not the point it you pay for a good tv then you want it spot on pal
07-06-2020 01:24 PM
Ok, so I spent around an hour this morning with Sammy customer services who remote accessed the TV but were unable to solve the issue. Engineers visit has now been authorised so I'll keep you posted...
07-06-2020 02:01 PM
Thankyou camelface let's hope and pray that Samsung can fix this problem.if thay do then I will be on the phone to them to get mine done
07-06-2020 05:31 PM
@Camelface Hopefully some joy from the engineer visit.
For anyone who has this issue the advice from Sky on Samsung models is return to Sky Q Home, and then trying to watch in HDR again. However obviously will not sort it for everyone.
07-06-2020 05:46 PM
