18-03-2017 01:59 PM
Hi,
my universal remote "rmcspk1ap1" has recently stopped working in the voice control.
no matter what you command it instantly comes up with "I did not recognise what you said".
everything else with the remote works fine, I have replaced the batteries etc but still no luck
any help appreciated
thanks
18-08-2017 01:42 AM
You would be correct AntS. The problem has only occurred while using the web browser. My model no. is UN55MU6300, and the software version at that time was 1123.
18-08-2017 09:56 AM
20-08-2017 02:11 AM
21-08-2017 12:13 AM
21-08-2017 10:16 AM
Hi @carolellogram2.
What model TV do you have? And are you able to get into the settings to tell us what the current software version on it is? (Settings/Menu > Support > Contact Samsung/About This TV)
23-08-2017 12:44 AM
Hello,
06-09-2017 09:26 PM
I own a UE49MU6102 model. During the past few days when i perform most voice commands (especially "channel X", "volume commands", what time is it" etc) that used to work, it now opens a new window with suggested search results with youtube videos. (Even for general questions, it used to bring google results, not Youtube!!!)
I have tried everything (even Settings/General/Start Setup), keeping the channel settings though) but still have not managed to resolve the issue, which is really annoying..
I also re-installed Youtube (it cannot be removed), but the problem remained...
Any ideas?
14-09-2017 01:25 PM
my tv does not change to the channel voice command. I worked earlier Did I do something?? Whats wrong??
16-09-2017 09:31 PM
I have the the same problem... I called samsung support and they said it is a problem for the whole MU references, so, they are working on some sofware updates to solve the problem.
The problem is known since 3 months ago and they have not solved it yet, so there is a lot of uncertaintity in the exact date to solve our problem.
They should not sell this references if they have that problem, this is an abuse for customers.
Let's see.
21-10-2017 08:29 PM
I am experiencing the same problem with my remote commands.
Have you resolved this at all?
Thanks
