02-04-2018 10:29 AM
Something weird going on here , nothing has changed but now sky q is saying my q7f is not UHD compatible , anyone ?
02-04-2018 11:33 AM
@paulyoung666wrote:Something weird going on here , nothing has changed but now sky q is saying my q7f is not UHD compatible , anyone ?
I often find when something works fine one day then not the next and you have made no changes then it is a fault with either TV or sky. Try another hdmi port and make sure the port is set to uhd enabled. Also report any faults to your retailer as soon as possible so the issue is registered and they may have an idie.
02-04-2018 08:19 PM - last edited 02-04-2018 08:56 PM
Hi @paulyoung666 , likewise I would check that UHD colour is set to on with the Skyq port. Just confirm your picture resolution is set to 2160P for viewing UHD in the Audio Visual Preferences of Sky Box, you may wish to use 1080i for HD content and let your TV do the upscaling (though seem folk constantly leave it on 2160P). If that is not the issue I would firsty reboot the Skyq Box (disconnect power for 30 seconds to see if it makes difference when back up and running) before trying another port. Another possibility is your HDMI cable but if is relatively new not that likely to be a factor.
