Go to solution Solved
Registrazione TV Led UE46b7000ww
(Topic created on: 14-12-2016 11:09 PM)
Foggetty
Buongiorno ,non riesco a registrare tra i miei prodotti la mia tv led modello: ue46b7000wwxxc
Ho inserito il serial number indicato sull'etichetta posteriore del TV, ma il sitomi dice di verificare il seriale inserito in quanto non corretto.
Esiste un modo alternativo al sito di Samsung People per eseguire questa operazione?
Grazie
       Ettore
EmmaS
Pathfinder
Our Italian friends are definitley the best people to speak to about regsiteing your TV.
If you get in touch with their Customer Service Team, they may be able to register your TV for you. We're sure if you've posted on the Italian Community, they'll get back to you soon to advise on this.
Have a good day! :womanhappy:
3 REPLIES 3
EmmaS
Pathfinder
Hey Foggetty!
Our Italian isn't that great, can you post this in English? The Community can then try and help you!
Alternatively, Samsung Italy have a great Community!
EmmaS
Foggetty
Sorry Emma
using the phone to write te post, it goes on the English community.
I try to translate, in the mean time I'm writing on the Italian community:
Hello, I can not register my products my led tv model: ue46b7000wwxxc I entered the serial number shown on the back label of the TV, but the white phosphorus exposure says to check the serial posted as incorrect.
There is an alternative way to the site of Samsung People to do this?
Thanks
EmmaS
Pathfinder
