Question about 4K/UHD
(Topic created on: 30-06-2017 11:42 AM)
johnrbull
I have a new UE65KS9000.
How can I tell if I am actually watching a movie e.g Amazon Prime Video 4K/UHD movie in 4K/UHD on my TV? Does the TV see that the format I am watching is 4K/UHD and adjust automatically, or do I have to select something manually?
1 REPLY 1
blacksson
Hi,
If you are sure that you play UHD movie, TV should automatically show it in UHD format. There might be an info button on remote to check the video format.
