16-02-2018 03:10 PM
Hi all, just got a new TV (model number listed above) and Im pretty sure it said it offered HDR 10. I have a ps4 pro but I cannot get the ps4 to recognise the TV is HDR. I have gone into external devices and activated the HDR UHD for the port connected to the ps4 pro. I have also tried it with on game mode and without game mode, no matter what I do I cannot get the ps4 to recognise that the TV is HDR. I honestly can't figure it out. Please help!
Solved! Go to Solution.
16-02-2018 03:15 PM
Hi, thanks for getting back to me so quickly. I managed to find the problem. Which I'm sure a lot of people will benefit from. I have installed the Psvr system which runs the hdmi port through it into the TV. The Psvr box doesn't support HDR so I needed to bypass it. Hope this helps anyone who else runs into this issue.
16-02-2018 03:12 PM
@Jaykobi131wrote:Hi all, just got a new TV (model number listed above) and Im pretty sure it said it offered HDR 10. I have a ps4 pro but I cannot get the ps4 to recognise the TV is HDR. I have gone into external devices and activated the HDR UHD for the port connected to the ps4 pro. I have also tried it with on game mode and without game mode, no matter what I do I cannot get the ps4 to recognise that the TV is HDR. I honestly can't figure it out. Please help!
Have you enabled the uhd mode for the hdmi input for the PlayStation as it is off by default.
Paul
16-02-2018 03:15 PM
07-01-2019 07:40 PM
the new one support hdr passthrough look for the code barcode if it reads
CUH-ZVR2
your ok
https://www.engadget.com/2017/10/02/sony-s-updated-playstation-vr-won-t-block-hdr/
