Is UE55MU7005 supporting REC.2020 ?
(Topic created on: 08-03-2018 03:16 PM)
JaimeFdezCaro
Hi, I have been trying to activate HDR option on Windows 10 + Intel 620 with my Samsung TV UE55MU7005 but unfortunately I have not sucess yet.
Win10 settings:
https://support.microsoft.com/help/4040263/windows-10-hdr-advanced-color-settings
In order to have HDR option active your system need to accomplish be capable of: HDR + Advanced color.
As per DxDiag tool I can see that is reporting that TV is HDR capable but is not supporting Advanced color features: BT2020RGB or BT2020YCC; Eotf2084Supported; AdvancedColorSupported; AdvancedColorEnabled.
Also, DXGI_COLOR_SPACE_RGB_FULL_G2084_NONE_P2020 is not appearing on Text Report.
I tried different HDMI 2.0b cables and also to connect my PC not directly to the TV but through LG SJ9 sound bar... same results. By the way, HDMI UHD Advance Color option is already Active on my Samsung TV.
Can you tell me if UE55MU7005 is supporting advanced color features? Any ideas how to make it work on Win10?
Thanks and best regards!
0 REPLIES 0
