Support
Open search
Help with New TV
New Member
Just purchased a Samsung UN55NU6900 55 inch 4K tv.  When the tv is powered off, there is a red light which comes on at bottom of set (and stays on) which flashes intermittently--- will stay on for maybe 20 seconds , shut off, then come back on etc...
Is this normal or should I return set?
2 REPLIES 2
AsadM Moderator
Hi @techowiz19. Thanks for getting in touch. Where did you buy your TV from? Also, where are you based?
New Member
Purchased tv from Micro Center in Westbury , Long Island. I live in Bethpage , NY area. Bought tv 2 days ago.
Top Liked Authors
