Support
Open search
Games not working on Samsung TV
I have a UA40F6400AM Samsung TV and none of the downloaded games will work - e.g., Nitro Chimp, Chess etc. I have reset the SmartHub but when I click on PLAY it tries to connect but then comes back to the games page.
Can anyone help please?
3 REPLIES 3
ChrisM Moderator
Hi @BrisbaneMike.
Could you check the software version on your TV? You can find this by going to Menu > Support > Contact Samsung.
Thanks for the message. The version was T-MST12UABC-2132.2, BT-G.
I then updated it and it is now T-MST12UABC-2139.1, BT-G.
The games still don't work.
Michael
ChrisM Moderator
Are you still having the same issue, @BrisbaneMike? If so, Let's try resetting the TV. Go to Menu > Support > Self Diagnosis > Reset. Note, any saved settings will go back tothe factory default settings. Let us know how you get on.
Top Liked Authors
