05-01-2020 01:25 PM
I just bought a Samsung 43RU7400. I set everything up apart from the smart remote. Whoever made the design clearly wasnt doing their job correctly.
The remote so thin that its extremely hard to remove the rear of the remote to put in the batteries. It's hard to use your other hand to hold the rest of the remote so you can remove the rear. Ridiculous
