BBC I player blurred
(Topic created on: 13-01-2019 04:27 PM)
Pete15482
Does anyone know why i player goes blurry on Samsung tv after about ten seconds? All other Apps work fine and no problem with the internet connection. It is driving me nuts!
5 REPLIES 5
CarlH
Hi @Pete15482. Is the resolution changing by any chance? What's your download rate like?
Pete15482
Hi. It just goes very blurry after about ten seconds of being fine. Download speed is fine. I’ve just tried the old trick of unplugging and turning back on and it is working fine. Do you think it might be something to do with system updates?
CarlH
Could be a possibility. What's the model number of your TV, @Pete15482
Pete15482
Hi. It is UE43NU712 0. Thanks
CarlH
Thanks, @Pete15482. The latest version is 1231.1. If yours isn't this and you're unable to install it directly, this link will allow you to download the file to a USB stick (using a computer) and install it using that.
