05-07-2019 09:44 PM
Hi, I've just got a new 2019 QLED TV today and Bixby randomly comes on whilst watching TV. I've tried to find ways to stop it but I can't see how. Has anyone else had the same problem or know a solution?
Thanks
29-10-2019 12:55 PM
I have the same problem.
Voice control consistently says it's experiencing technical difficulties.
I've had Samsung remote support and tonnes of emails, updated version on the TV 100% sure but it always interupts viewing, like the TV thinks it is hearing a bixby command and doesn't do anything.
I've reset the tv and remote various times. It's incredibly annoying and can't seem to find anyone else with the same issue and Samsung themselves cannot solve it.
My TV viewing is interupted all the time by this annoying bixby and I can't access settings to disable it.
Any help at all?
29-10-2019 05:19 PM
I have the same problem......annoying isnt it?
30-10-2019 04:28 AM
Adjust the sensitivity for Bixby that's how I solved the issue. It's in the TV settings.
30-10-2019 12:19 PM
Hi tribum
Yeah that sounds easy right! it doesn't work, it won't let me access anything to do with bixby in any setting. I've tried loads of options, soft reset, hard reset. reset the remote. check for updates. samsung assistant has tried and tried to no avail. my last email from samsung said they have passed up to some technical department to check.
30-10-2019 12:20 PM
25-11-2019 09:19 PM
28-05-2020 09:51 PM
Was anyone able to solve this?
28-05-2020 10:00 PM
Hi Purple80.
Yes I reset the whole tv and upon set up I entered another postcode in England, I dont live there, but that has now removed the error I was having. Still cannot access Bixby but dont want to anyway. Samsung clearly has some issue with my particular location
