Support
Open search
S8 smart lock - trusted location issue
Observer
I added several trusted locations within my home, trying to bracket the place. Let's see how that works.
I have an S7. After spending a lot of time following the procedure you referenced, which I found elsewhere first, this SIMPLE method is what finally worked for me.  I stumbled onto it:
SMART LOCK FIX SAMSUNG GOOGLE
For Home setting not working:
In Settings, Go to Location. Toggle it OFF then ON! It Resets it! ☺
Found an easy solution:
1) Open Settings - Apps
2) Find Maps and select Storage and in there press CLEAR CACHE
No need to clearn Samsung cache or reset anything else. It seems that Maps app cache gets corrupted time to time when phone updates its apps constantly. Sometimes Maps can fix it when I just open Google Maps and zoom into my current location. After the latest major system update this didn't help at all, but clearing just Google Maps cache did help immediately. This fix may work with some other brand phones, too.
Hi, try my solution which I just posted. I think that might help...
Thank you x
Observer
I have the same issue with my s8. Very annoying and I've cleared cache and did everything necessary then it started working then after 3 hours again same thing. They don't really care about us :(
I went into settings>device maintenance>battery>battery usage, press three dots in top right, optimize battery usage, choose all apps, then went down to location services and unselected it, seems to be working now, I know after update when screen went off GPS would go off and location would drift so took it off of the battery optimization so hopefully it runs while screen off, not sure but seems to have been working since I did that yesterday, to verify that's on my s8
Check where Google Maps locates you when Smart lock isn't working. In my case it sometimes locates me just outside the range to the opposite building. Adding these a-bit-off locations nearby helped me. It's a pity that one can't define the range what is considered safe distance.
Unfortunately mine seems to randomly drift, once it said I was about 5 miles SW in a lake, trying to set up a location based IFTTT last night it had me about 2 miles NW
Just a thought. If you are not using GPS to locate your position then your location is being triangulated by cell phone towers which are not accurate at all.  Check to see if your Settubgs-Connections-High accuracy is turned on or not.
Top Liked Authors
