Support
Open search
S9+ call volume low
Same here! 😔😔😔
I didn't think anyone else could be as dumb as I am, lol
New Member
I got A1 sauce in mine and have been having problems so i tried this and it worked immediately! Thank you
What did you do to fix it?
New Member
I had the same issue. Later on, I figured out that it was the speaker been blocked by melted chocolate. It happened when I put chocolate in my pocket where my S9 was there as well. I turned off the phone, cleaned it using damped cloth with clean water. The volume is back!!!
New Member
Yes ive noticed now i need to use my speakerphone to take calls and my phone is relatively new . Tried everything to no avail . Any luck with a fix ???
Observer
I'll be returning my 2nd S9 for girlfriend today. In call volume barely audible. Talked to an intelligent tmo rep/tech support after signing in with a new similar and he thinks possibly it's something to do with the backup software after installation. Lasted 2 weeks on the 2nd phone and then in the middle if the call, bam, the volume dropped.
Only option is to do all new install instead of from a buckup/restore.
New Member
Did u find a fix?
Yes it was a screen protector covering the hole . Just changed the screen protector work's fantastic now !!
Top Liked Authors
