Support
Open search
S9+ call volume low
I'm having the same problem. Mine was a pre order too. Have you been able to find out the reason it is doing this? Mine's not been dropped or had liquid anywhere near it. Tyia
This is the 2nd S9 I have received from T mobile and the issue is I cannot hear the other party on the phone when I have it to my ear. I have called Samsung and they suggest that you go to Samsung.com/support to lodge a complaint. I would not recommend this phone don't purchase.
I know this is the 2nd s9 I received from T mobile. I called samsung and trouble shooting didn't work. T mobile sending me a my 3rd phone. They need to talk to samsu lng.
Yep, this is the 2nd phone I received due to this problem. I called Samsung twice and they don't seem to care.
New Member
Just received my Samsung S9 over the weekend and I noticed that the call volume is very low. Also, when using the speaker the call goes in and out. The caller on the other end cannot hear you.
New Member
Hey, Do you fixed that problem . I am also struggling  with same problem . Can you please tell me how to fix this problem.
Mine issue was the screen protector.  Once I removed it the sound was great again.
New Member
Thanks. Thar
Been about three weeks now and I have to use the speaker to hear the call. Very irritating, anyone find a fix?
I just figured out that any liquid other than water can block the speaker on front screen.
Whilst cleaning the spearker with a damp cloth remembered my daughter accidentally dropping a few drops of milk on it a few days prior.
(thoughror clean with damp cloth, using water only and blow it dry)
This worked immediately for me!
Top Liked Authors
