Support
Open search
LED view cover for S9+ not working
Highlighted
Led view cover on s9+ not working after Android 9 Pie update. Anybody got any suggestions?
5 REPLIES 5
Highlighted
Bonjour meme probleme que vous sur galaxy s9... je crois que android 9 pie n'est tout simplement pas compatible pour le moment... il va falloir attendre une nouvelle mise a jour
Highlighted
New Member
Idem chez moi depuis la mise à jour vers android pie 9 le led view cover ne fonctionne plus du tout  sur mon Galaxy S9+... :(
Highlighted
New Member
Similar issue. Cover is causing phone calls to end after seconds and apps like spotify also stop with great frequency. Leds still work but case is now useless.
Highlighted
New Member
I updated the LED Icon editor, added an icon for a contact and it started to work again.
Highlighted
New Member
I managed to resolve it by starting my phone to safe mode. Press down the power and volume down buttons. When the phone restarts let the power button go, but keep the volume button pressed. This will boot the phone into safe mode. Once the phone boots you will see your case working. Restart your phone, problem solved. I hope this works for you.
Top Liked Authors
