Support
Open search
How to fix wifi speed issues
New Member
My wifi speed is very pour on s9+ worse than my old s3.
1 REPLY 1
AndrewL Moderator
Hi @MaryS9
At this stage to troubleshoot your issue I recommend restarting your router then going to Settings > Connections > WiFi > Choose your WiFi router > Forget, then re-add the router using the 'add network' option. You can also try connecting to an alternate router, a friend or family members, to determine if the issue lies with the phone or your existing connection.
Top Liked Authors
