Support
Open search
Gap between front glass and aliminum frame
New Member
Hello Everyone,
Suddenly I have noticed that there is a gap between front glass and metal frame on my s9+.
I can easily insert a piece of paper slightly on the side and bottom.
So i am afraid whether i have received any defective piece or not.
please let me know is it normal or not.
thanks.
1 REPLY 1
AndrewL Moderator
Hi @GalaxyS92
It's difficult to diagnose any potential defects from this position however if you are concerned then I'd recommend visiting a Support Centre where an authorised engineer can inspect the phone for you. You can find your nearest one by checking the following link, selecting 'Mobile Device' and entering your post code: http://www.samsung.com/uk/support/servicelocation/.
Top Liked Authors
