27-07-2019 07:21 AM
Hello Everyone,
My s10+ battery drain is unbelievable. Please can anyone help me out on how to resolve it. I am getting frustrated with it. Thank you
Solved! Go to Solution.
28-07-2019 06:25 AM
My advice is to put the phone in Safe Mode which disables your downloaded apps and leaves the stock ones working and then see what happens.
If it improves then one or more of your apps is causing this or a theme or 3rd party launcher if relevant.
Come out if Safe Mode and start deleting your most recent apps one at a time until it stops.
If this continues in Safe Mode and all your systems are up to date and your signal from your network is strong then try a back up and factory reset as a very last resort.
A Samsung Experience Store or Samsung Service Centre can run a diagnostic test on the phone.
Daily Driver > Samsung Galaxy s²⁴ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
28-07-2019 06:25 AM
28-07-2019 12:04 PM
Okay, thank you for your suggestion. I checked for software updates and after the update i am having a decent battery life
28-07-2019 12:17 PM
Good to hear @Ipo1
You're very welcome.
