Support
Open search
S10 Battery Drain
@TimC80 wrote:
Maybe there are a few operators suffering from the same thing, but there definately seems to be something up with EE
SOunds like what I thought that some carrier firmwares and really poor - someone with a unlocked samsung BTU firmware could maybe tell us how they are getting on?
I will be heading into samsung store this week to show them my results and see what they say - if its not a carrier firmwares then I wonder if EE's 4G signal to the S10 range is bad? I say this because although 4G is making battery bad, the firmware is still running when using wifi and battery is good :/
I'd really like people to say if they are unlocked on samsungs firmware -
Just to let everyone know I'm using a unlocked galaxy s10 which I bought straight from Samsung and I also have the battery issue when using cellular.
What operator are you using and in which country are you?
I'm in the UK and use BT
Okay so maybe Euro chipsets suffer from 4G data? Or outright is this a antenna hardware issue :(
Need Samsung to look into this - any reps or mods here?
BT mobile and EE are the same network actually, I think we are starting to see a pattern
We can rule out it being the full firmware - wifi with data turned off it perfect, remember the signal for call and text is still on so surely not a antenna issue (hardware) I hope - this issue wudnt show up on battery stats or device care too - its some deep issue in how the 4G data is coming in . SAMSUNG HEAR US
Surely somebody from Samsung is checking this forum. It's one of the most active forums here.
I am on Vodafone and in the UK
charging my phone after 24 hours
i had 4 hours 23 minits  screen time
and still my battery is 48 percent
and i am using wifi 24 hours my phone is connected with wifi
these recent changes had done alot of diifference in my phone
it just took 52 percent for 4 hours screen time in 24 hours
i think  while waiting for samsung to fix their issue  i can just  use it with my tricks and changings
even though i know we should not be needing any modifications for battery timing  coz its a latest phone but still i expect its just a software issue so while waitng for their fx we can just use custom ways to boost battery timng
Top Liked Authors
