Support
Open search
S10 Battery Drain
Highlighted
123 pages and still no fix or reply from samsung  this is just crazy i still lose so much % every hour  every day charge last time in 10 years i will not buy a samsung again they dont have any honor
Highlighted
Observer
Really it has battery issue? I was thinking to buy it.
Highlighted
Observer
Hi all
Same issue here in New Zealand. Just brought a new Galaxy S10 last weekend and I cant believe the battery drain. Its far worse than my 2 year old iPhone X (I only switched to Samsung as the ios 13 update ruined my iPhone).
As so many have aleady stated we should not have to switch to low screen resolution and switch off all the features to make the battery last for a reasonable time. It was advertised as 3400mAH, but I know of at least one App that reports it as 2500mAH wonder if thats closer to reality. Anyway it is so dissapointing. I have changed resolution to lowest, turned off everything, and since I charged it this morning  it has been on for 1 hour 22 min with 28 min SOT and batt now at 91% and dropping fast.
The Iphone X would still be at 100% and as for the Huawei Mate 20 Pro it runs movies and all day with great battery life.
What a shame as the S10 is a beautiful well appointed phone.
Samsung needs to step up and offer a fix.
Cheers all
Highlighted
It may be related to mobile network.
I have suffered a lot about 3 months after buying the phone. For the last two month the problem is gone. Before i used a subscription from a network provider(teletalk) in my country, which is reputed bad for poorly optimizes network. The day i switched to new network provider which has a moderate reputation(Grameenphone) in my country my battery drain problem is gone. On the older network i used to get 3-5 hr of SOT on a 10-13hr usage and idle battery drain was 3% per hr. Now I'm getting 5-7hr SOT on a 16-22hr usage with no power saving whd+ regulation. For me the culprit was bad network and the phone was fine. Try switching network provider (if possible). And see if ur device is faulty or its just badly optimised network?
Highlighted
I am actually using my S10 from around 12 hours every day and I spend at least 1 and half hour per day on mobile game.
Of course, when I am not using my phone, like when I walk on the street or when I work, I try to cut the mobile data as much as possible to save my battery, but I don't often need to turn ON the battery saving mode.
Highlighted
Navigator
Also, Android 10 seems to have really helped battery.  When I got my phone I was getting about 8 hrs SOT - maybe a little more when I disabled all the bloatware.  Then, the bloatware came back and my battery dropped significantly.  Also, every update I did seem to make my battery worse as well and was getting only about 4 hrs SOT. I lived with it but wasnt happy about it. I have updated to Android 10 and I am getting 8 hrs SOT on a single charge doing all the same things I was doing before - could probably get a little longer but I generally charge my phone at about 20% (and charge it to about 90% only).
Highlighted
Navigator
I somewhat take it back...I stopped a certain process which suppressed apps by accident (cant get it back either) and now my battery drain is pretty bad... :(
Highlighted
New Member
Only 9 hours battery? Any suggestions? On official android 10 release...Only 9 hours battery? Any suggestions? On official android 10 release...
Highlighted
Same here. Asked provider for new phone but they keep skirting the issue. Seems to be a general issue then. Told to close every app and Google as creating a drain. I'm charging twice a day and not using phone a y differently to my last phone
Highlighted
Honestly at this point I'm going to take the $600 trade in and move on.
Top Liked Authors
