Support
Open search
Small bit of dust under Note 9 camera glass.
Highlighted
There is what looks to be paper or dust under the camera glass of my Note 9, don't really know how it got there as it hasn't spent a minute out of a case. Not major but would like to remove it if possible as it is quite noticeable, or know how it got there. 20190110_174720.jpg
4 REPLIES 4
Highlighted
Superuser I
Superuser I
How long have you owned the phone @Glenn_ ?
I ask because some sellers give a 30 day cooling Off period to be able to swap it out.
If this isn't an option then a Samsung Experience Store or Samsung Service Centre can help you.
My advice comes from being a UK Samsung Phone User.
Current Phone ~
Samsung Note 10+ 5G _256Gb > Model: SM-N976B._ Samsung One Ui 2.1 / Android 10.
Samsung Gear s3 Frontier Watch.
Samsung Galaxy Buds.
Samsung Galaxy Tab A {2016}SM-T580
Highlighted
Pretty much since release so swapping it is not an option unfortunately. Will try and visit a store soon, thanks. Annoys me as I had a cheap phone for 2 years before this, didn't even buy a case for it and had no issues with dust.
Highlighted
Superuser I
Superuser I
It can happen with any phone to be frank @Glenn_ wether it's a feature phone or a flagship.
As a rule of thumb I always buy my phones from a Samsung 'Bricks and Mortar Experience Store and open it up in-house to give it a thorough check over.
However instances can arise where either some dormant dust is already in the phone and travels around it or somehow dust gets in as the phone is ip68 which is dust resistant which means it repels dust but it can in rare instances get into the phone.
I'm sure a Samsung Service Centre will look after you  ..
Current Phone ~
Highlighted
New Member
I have the exact same thing on mine so I'd ont believe it's dust now. I wonder what it is
Top Liked Authors
