03-04-2019 09:45 AM
Hi All
i have started to experience an annoying bug
My phone is set to automatically enter battery saving mode when the battery % falls below 15% which works fine.
My issue is, whenever I then start charging my phone/exit battery saving mode, my Apps dissapear from my app draw and my home screen icons vanish, apart from the facebook icon?
If i use the search bar and type in an app , it will locate it in search and I can access the app. BUT my app draw is COMPLETELY EMPTY apart from the basic system apps!
To fix it I have to restore my home screen from samsung cloud and my apps and icons then return.
this is extremely annoying and only started happening since last friday!
I have wiped cache partition/ cleared cache samsung home and nothing has worked.
Is anybody else experiencing this bug?
Thanks
