Support
Open search
Samsung Galaxy Note 9 Battery Drain ?
SOLVED
Hi all i been a proud owner of the Galaxy Note 9 for about a week now. i love the Note 9 but what's up with the battery ? Like today, i had 100% i must of watched a video on YouTube about 10 mins, and the rest with background playback screen off.. this was about 4pm so about 5:10ish pm i turned the background playback off..
I hadn’t touched the phone till 1am i.e standby only Bluetooth off 4G and sync  on screen res at FHD i have lost around 27 percent battery that is awful ? My Tab S 8.4 is over 4 half years old even that don’t have this much drain sync on, 4G on, no wi-fi, no Bluetooth.
For example i can leave the Tab S 8.4 overnight it will lose about 4% to 5% overnight not bad for nearly a 5 year old battery
But Note 9 will lose more than 15% to 20 + % overnight there is something not right?
Other thing Samsung i don’t want to root the my Note 9 (But you’re not leaving me much option) You installing all this Facebook garbage ? And you not allowing me to uninstall from the phone witch i purchased (Sim Free) is a bit of a joke ? What's up with that ?
I hate carrier bloatware that’s why I always purchase my smartphones sim free.. But now your installing Facebook bloatware is a bit stupid! Not everyone purchases a high end smartphone to use Facebook. Samsung please compute that! There should be a option to have unbranded firmware.. Thanks
Tab S 8.4 SM-T705 LTE
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Galaxy Gear Frontier Gear S3 SM-R760
2 ACCEPTED SOLUTIONS
Superuser I
Superuser I
Hi @TH3ROY
Best place to start troubleshooting is to look in your battery stats.
Facebook can be stopped in the settings and a package disabler in Playstore can rid the phone of bloatware - just be careful what you disable.
There isn't always the need to "root" the phone.
Another option is to put the phone in Safe Mode which disables the downloaded apps and leaves the stock ones Live which can help you determine if its a rogue app if battery returns to normal.
A Samsung Experience Store or Samsung Service Centre can run a diagnostic on the phone too if you deem it necessary.
Current Phone ~
Samsung Note 9 Model: SM-N960 Dual Hybrid 512Gb
Samsung Gear s3 Frontier Watch
Samsung Galaxy Tab A {2016}SM-T580
Got my replacement NOTE 9 yesterday the battery is all ready working awesomely only lost a few percent in a 8 hour span awesome. i'm keeping this NOTE 9 Thanks Samsung you rock!
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Superuser I
Superuser I
Hi @TH3ROY
Current Phone ~
DannyT Moderator
Hi @TH3ROY,
Have you been able to try the suggestions given by @BandOfBrothers?
 Welcome to the Community! :smileyhappy:
Not sure how to get into safe mode? Will google it. Also i did read online, it takes about a week or so for the NOTE 9 to learn usage pattern, and for the battery to adjust. Not sure how true that is ?
It’s been over two weeks today I lost around 40ish % today. That’s from 4pm ish till 01:00 am my Note 9 was only on standby with 4g on, and sync on.. Everything else off, and I didn’t even touch the phone just in pocket..
Also I did try nova launcher as someone somewhere said Samsung launcher is the Android System drain, is that true ? it worked good for a few days then the drain came back..
It’s a massive joke my main culprit is for battery drain is Android System and Samsung email client these two are the main suckers. Android System is taking up a chunk of the battery just for being in standby how can I fix the Android System battery drain? And please note I’m using official Samsung email client and that’s got an fairly big drain as well..
I have just booted into safe mode will run for a few days see how I get on.. Also I did check App issue report nothing is begin highlighted or shown in there. Thanks
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Safe mode is no good everything gets disabled all my apps so i don't see how that is useful to find the culprit app ? Today 7-am i put the Note 9 into flight mode, come 4-pm i checked phone i had lost 1% it was 80% when i put into flight mode and it dropped 1% battery when i turned off flight mode sync on 4g on bluetooth on as i needed to sync my Gear S3 data..
so it seems like this could be a network drain and Android System keeps sucking battery when network is on.. Can some please let me know can Samsung Remotely diagnose my phone ?
As the Samsung Experience Store is in london i'm 170 miles away :(
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Never mind phoned SAMSUNG they offered to replace my NOTE9 i'm gutted as i cant be without  a phone as i would have been happy if remotely they could have fixed it.
But the rep goes it sounds like a faulty phone and remote can't really do much gutted!
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Tab S4 SM-T835 LTE
Note 9 SM-N960F
Top Liked Authors
